| Hi,
I know Valence was mentioned recently in a why-hasn't-Big-Oil-killed-them-yet way, but has anyone here any actual experience of using their Li lead-acid-replacement batteries?
For example, the U27-12RT is meant to be 12.8V nominal 130AH, thus possibly >1.5kWh usable charge assuming a ~90% safe DoD (cf 50% for lead-acid), in a much smaller and lighter pack than lead-acid. (I've just emailed Valence and I have found the datasheet too...)
One possible advantage is that the built-in controller may eliminate the need for a separate charge-controller for 12V-nominal solar panels, and indeed an LVD too.
Any comments?
Moved to the proper section. A link would help get more comments, too.
92 Scoop users have viewed this posting.
