Screw in anchors
By mbeland, Section Mechanical
Posted on Mon May 5th, 2008 at 12:02:44 PM MST
Can I salvage dig out old utility ones?
These seem to be left unused by the utility company. They would be free. I guess a lot of hard work would be involved in digging them out but ecologically speaking, time is not an expense...! Has anyone ever tried this? How deep are they? Can they be screwed  in again or did you just use them with concrete?
Martin
Screw in anchors | 4 comments (4 topical, 0 editorial)
Re: Screw in anchors (3.00 / 0) (#1)
by phil b (philb7369at-no-more spam-yahoo.com) on Mon May 5th, 2008 at 12:02:25 PM MST
Hello Martin,
The electricity grid type anchors I have experience with are about 8 feet long. You may be able to dig around them and pour water in the hole to loosen them up a bit. To unscrew them, use a BIG prybar. You'll have to judge all the hard work invested for what you get in return.
Re: Screw in anchors (3.00 / 0) (#2)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Mon May 5th, 2008 at 12:12:11 PM MST
The anchors can run about 40$ each or more, depending on how big they are.  If you get one out and it isn't rusted away, then you have something worth salvaging, IMO.
That is - if you can actually get them out of the ground.
They may look like they screw in, by they may have big flat plates down there, instead.
Steven Fahey
Re: Screw in anchors (3.00 / 0) (#3)
by kenputer on Mon May 5th, 2008 at 04:46:18 PM MST
The ones that I used had a large flat plate on the bottom with a 3/4" bolt,if they are the same style you should be able to unscrew them from the bolt and pry out.
ken
Re: Screw in anchors (3.00 / 0) (#4)
by Gog on Thu May 8th, 2008 at 03:14:53 AM MST
From my dusty old memories of installing screw anchors ,we used to screw them in vertically with a crowbar through
 the eye and a bloke on each end and then bend the top foot over to line up with the stay wire, which would
have to be straightenened up before recovery.
I guess your chances would depend on age and soil type.
But I can remember getting a few back out.
cheers
Keith
· Also by mbeland
