38 volt ametec power
By JW1111, Section Wind
Posted on Tue May 6th, 2008 at 12:17:01 AM MST
I was just about to ask this question when I read the other one on the the 30 volt Ametec, and did not want to hi jack it so I will ask the same question for a 38 volt. How much power (amps) can I expect in 14 mph winds when charging 12 and 24 volt batteries?  Thank you.
38 volt ametec power | 7 comments (7 topical, 0 editorial)
Re: 38 volt ametec power (3.00 / 0) (#1)
by kurt on Mon May 5th, 2008 at 06:25:41 PM MST
i have heard that the 38v amatek is not as good a performer as its 30v brother i hear about 50-60 watts max at 12v with a 4' prop.
http://www.reresource.org/
IRC
Re: 38 volt ametec power (3.00 / 0) (#2)
by fungus (info@reenergy.co.uk) on Tue May 6th, 2008 at 04:19:16 AM MST
I have seen about 2.5A in a 14mph wind from my ametek 38v with 4' wooden blades.
Fungus - www.reenergy.co.uk
Re: 38 volt ametec power (3.00 / 0) (#3)
by fungus (info@reenergy.co.uk) on Tue May 6th, 2008 at 04:28:34 AM MST
A bit more info ..
I've got an anemometer and did a rough hand-drawn graph .. this was mainly to find windspeed distribution where I am but I quickly drew on some amperage values ..
I have seen a maximum of 7A from this motor in about 30-40mph winds ..
Re: 38 volt ametec power (3.00 / 0) (#4)
by Basil (basil(spamblock)key@bellsouth.net) on Tue May 6th, 2008 at 04:51:26 AM MST
I have SEEN 45 watts out of my 38-volt mill. I'm sure it's did more. It has 3ft dia industrial fan blades. Best wind I have had is maybe been 15 mpr while watching it. I love it. It is great to bring a battery back up slowly.
Bad luck or none at all.
Re: 38 volt ametec power (3.00 / 0) (#5)
by JW1111 on Tue May 6th, 2008 at 07:32:14 AM MST
just so I am clear, is that a 4' blade (radius) or a 4' (diameter) blade path?  I was going to make my blades 24" long but maybe I will go twice that.  thanks.
Re: 38 volt ametec power (3.00 / 0) (#7)
by TomW on Tue May 6th, 2008 at 09:13:16 AM MST
JW1111;
Generally we refer to props by their diameter. So a 2 foot blade will produce a 4 foot prop, plus a bit for the hub area. I can see where it is confusing but most references to power versus prop are by diameter. Swept Area is the area inside the circle made by the prop tips going around and it is the Holy Grail of turbine power output. There is no substitute for swept area.
Hope that helps more than a sharp stick in the eye.
If everyone is thinking alike, then somebody isn't thinking.
--George S. Patton
Re: 38 volt ametec power (3.00 / 0) (#6)
by fungus (info@reenergy.co.uk) on Tue May 6th, 2008 at 09:01:24 AM MST
Thats 4' diameter, each blade is 24"
  107 Scoop users have viewed this posting.
· Also by JW1111
