Hughs 4 ft stator finished.
By Jerry, Section Diaries
Posted on Wed May 7th, 2008 at 02:41:45 AM MST
multi tap conections.
Since this stator is a test unit I've made conections for star or "Jerry Rigged" easy with the use of male 1/4" spade terminals.
Hughs 4 ft stator finished. | 10 comments (10 topical, 0 editorial)
Re: Hughs 4 ft stator finished. (3.00 / 0) (#1)
by elvin1949 (elvin1949@yahoo.com) on Wed May 7th, 2008 at 12:11:17 AM MST
  It is looking good. Can't wait to see what it will do.
Elvin
Re: Hughs 4 ft stator finished. (3.00 / 0) (#2)
by TheCasualTraveler (a.miklos@yahoo.com) on Wed May 7th, 2008 at 05:08:59 AM MST
Neat with the terminals. Never saw them like that before.
Andy
Re: Hughs 4 ft stator finished. (3.00 / 0) (#3)
by blueyonder (windwoodgood at yahoo dot co dot uk) on Wed May 7th, 2008 at 05:45:53 AM MST
hi jerry its looking good.
  but i asked you on your other post about what the white stuff is you used on the stator.    did you use it to save resin . or is it better for heat transfer.
  it might be  commem material's whare you are .but i cant make out what it is.
Re: Hughs 4 ft stator finished. (3.00 / 0) (#4)
by tecker on Wed May 7th, 2008 at 06:22:09 AM MST
Yes sir I made a run at another poject I get back at the gensets some as one goes in the truck to power the hho cel I'm useing. Looks good
Re: Hughs 4 ft stator finished. (3.00 / 0) (#5)
by jmk on Wed May 7th, 2008 at 07:25:28 AM MST
 Hi Jerry, I too am wondering what kind of resin was used to hold the coils in? It's looking good. I've been wanting to make a four or six foot geny to transport around with my ice shanty.
jmk
Re: Hughs 4 ft stator finished. (3.00 / 0) (#6)
by Jerry on Wed May 7th, 2008 at 01:53:04 PM MST
I'm using standard fiberglass reson. The white stuff is fiberglass sheeting. Its used for building shower stalls. Its about 1/16" thick.
I've had some scraps left over from some other projects. Since its allready fiberglass, its very strong when stacked up and glude together as laminations.
Its very easy to cut with a router circal cutter. I use a scrole saw to cut the shape and location for the coils. I drill holes through the edge to form the coil wire exit.
This formate keeps the coils in the proper position and location (no drifting).
The amount of reson is reduced a bunch. I also use the sheeting as a magnet template. I leave this template glude to the steel disc perminatly.
This stator will be secured to a 12" speaker basket. This gives the stator 360 degree support. This whole asembly is very light but very strong. The speaker baskets makes a perfect mount for the bearing and shaft assembly.
Airheads Page
Re: Hughs 4 ft stator finished. (3.00 / 0) (#7)
by blueyonder (windwoodgood at yahoo dot co dot uk) on Wed May 7th, 2008 at 03:24:59 PM MST
 its folks like you who will save the planet Jerry.
Re: Hughs 4 ft stator finished. (3.00 / 0) (#8)
by jmk on Wed May 7th, 2008 at 05:01:21 PM MST
 I did read the part where you used the shower. It's great way to conserve. I am surprised to see that the other resin is so clear. That's why I was wondering. My polyurethane resin hardens in a greenish - yellowish color. I use the Bondo brand. That's going to be a nice little geny. I am anxious to here its performance.
jmk
Re: Hughs 4 ft stator finished. (3.00 / 0) (#9)
by Jerry on Wed May 7th, 2008 at 06:52:30 PM MST
The clear part in the center of the coils is plexi. I cut 1"X2"X3X8" pice of plexi. I cut slots on the sides of the plexi. I use this as a bobin in the center of the coil winder. The plexi pice stays in the center of the coil and is cast into the mold along with the coil.
The slots on the sides alow me to used zip ties to hold coil shape. Latter I replace the zip ties with white cloth tape. During handleing the coils expand a littel but the precut cut out in the stator form squishes them back into shape.
Next step is bearing and shaft assembly. Then its about time to do some RPM, prime driver requierments, volts at rpm, amps at rpm, watts at rpm, temperature of coil at watts for time running.
Ofcourse all these test will be done in star and Jerry Rigged. I can tell you quite confidently That start will run quite hot.
Airheads Page
Re: Hughs 4 ft stator finished. (3.00 / 0) (#10)
by Jerry on Wed May 7th, 2008 at 10:41:12 PM MST
Whoops. I should have wrote "Star will run quite hot"
I was at the retail store and a big crowed of people came in. I tryed to finish up to fast.
Airheads Page
  124 Scoop users have viewed this posting.
· Jerry's Diary
