| Can someone help me off board?
I have constructed the hardware for a 'gecko' and 'cockroach' catching machine. Its quite elegant.
The arrangement involves an infrared transmitter diode sending to a photodiode which in turn is picked up by a 2N3906 transistor - the output is high or low - x volts or zero. This is to detect the gecko or cockroach inside the machine.
I have a 12 volt solenoid to pull the pin on the trap door.
To allow the trapdoor to fall freely I need to hold the actuator pin inside the solenoid coil for about 1.5 seconds. I have been playing with a 555 IC to achieve this and studied it so much that I have become lost - all fails.
After the system has 'actuated' and the trapdoor falls, I want to turn off the entire circuit power to conserve the battery. I was thinking of a magnet and reed switch, but there must be something more simpler.
The power supply can be between 9 and 12 volts DC with battery, or, with mains DC by converter, but the solenoid is a bit slower with 9 volts.
I have photos etc, and if you can assist a 60 year old who is of 'fumbling amateur status" I should be very grateful.
At a push I am hoping to use solar power for charging which may be a poor excuse to keep this on the board for a short while.
My diect e-mail is strltd AT netvigator.com Change the obvious.
David HK |
112 Scoop users have viewed this posting.
