1HP 3P Motor Conversion Part III
By valterra, Section Diaries
Posted on Thu Jun 12, 2008 at 09:43:51 PM MST
Uh Oh! How do I mount the blade hub?
Part IV will be voltage tests with different wiring schemes (star, jerry, etc.) BUT....
I can't figure out how to mount something to it!  It has a keyed shaft, 7/8 inches in diameter.
For my Ametek, I bought one of Terry's arbors (tlgwindpower.com) which is a smooth female side that attaches to the motor with set screws, and a threaded male side with a nut and two very thick washers.  I simply drilled a hole in the center of my duo-blade, popped them on the  arbor's shaft, tightened the nut and was done.
With this one, I am having more trouble figuring it out.  Terry doesn't have anything that large.  Motion Industries guy says he can manufacture something for about $70.  There has got to be a better way.
So what do you guys do?  Zubbly's pdf files only cover the actual motor conversion, not blade assembly.
Once I figure this out, I can actually mount something to it and test the voltages.  I've sleuthed some data by turning it by hand.  And using the Duct-tape-on-my-drill method results in lots of broken tape when under load.
Thanks in advance for your advice guys.  Also the grooved slot is 3/16 inch wide.
1HP 3P Motor Conversion Part III | 10 comments (10 topical)
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#1)
by kurt on Thu Jun 12, 2008 at 03:51:20 PM MST
zubbly always bought a weld on hub with the proper hole and key way and welded that to a metal plate with a hole in it for the shaft to go though then he sandwiched the blades between that plate and another plate with a small hole drilled in the center of it for a bolt that goes in a threaded hole that he drilled and tapped into the center of the shaft secure the bolt with loctite.
IRC inst.
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#2)
by kurt on Thu Jun 12, 2008 at 04:30:21 PM MST
some photos directly out of zubbly'a irc gallery that is located here http://www.anotherpower.com/gallery/zubbly?page=1
IRC inst.
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#3)
by valterra on Thu Jun 12, 2008 at 04:31:40 PM MST
Thanks Kurt!  I was hoping to avoid welding something directly to the shaft.  That way, you can dismantle it if necessary.
But then again, on my Ametek genny, the set screws wore out and I ended up (JB) Welding it and the arbor together!  :)
That idea is on my list.  Would a Grainger or Fastenal type place have those?
Anyone else?
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#4)
by kurt on Thu Jun 12, 2008 at 04:57:13 PM MST
if i wanted a weld on hub i would go to a industrial bearing and belt supply store like motion industries they have a store just down the street from me..... but a large farm store mite have them like tractor supply or something.  https://www.motionindustries.com/motion3/jsp/mi/index.jsp
IRC inst.
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#5)
by wdyasq on Thu Jun 12, 2008 at 06:00:54 PM MST
The hub does not 'weld on'. The sprocket zubbly got welded to a hub that had the spline and all on it.
http://www.surpluscenter.com/powerTrans.asp?UID=2008061218524614&catname=powerTrans
Look at the sprockets and the 'taper-lock' stuffs. The taper lock was 'zubbly approved' and a damn good way to attach stuff to a shaft.
There are ways to attach prop to the hub with no welding. One could use a 'taper lock' hub and a large pulley. The pulley would then be drilled and tapped for the bolts holding the prop and backing plates.
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#6)
by valterra on Thu Jun 12, 2008 at 10:53:57 PM MST
What exactly is the "taper lock" idea?  I can't find a description online.
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#7)
by jonas302 on Thu Jun 12, 2008 at 11:04:27 PM MST
taper lock hubs are a two peice that bolts together tightening the taper on the shaft they hold very well look at surplus center.com dirindustrial.com  or granger
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#8)
by Flux on Fri Jun 13, 2008 at 12:14:37 AM MST
http://www.fptgroup.com/products/taperlockbushes.asp
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#9)
by valterra on Fri Jun 13, 2008 at 10:31:32 AM MST
Awesome page, thanks!   :-)
Flux, after I get some numbers, could you help me determine the right blade size?  It'll be next week at the soonest.
Re: 1HP 3P Motor Conversion Part III (3.00 / 0) (#10)
by Spdlmt150 on Wed Jun 18, 2008 at 02:46:23 PM MST
I am working on a 3hp baldour 3 phase conversion right now, and ended up going to motion industries to figure out how to mount a rotor. What I ended up with was the taper lock bushing, and a large sprocket. The bushing slides onto the shaft (keyed) and then the sprocket bolts to the bushing drawing the two together. Once they get tightened down it's impossible to remove even after the bolts are pulled - which is why they put 3 threaded holes in the assembly to use the bolts to press things back apart. I drilled hole patterns in the sprocket for mounting the blades & cut the teeth off the sprocket (would do a real job on the knuckles if they caught ya while turning) and have a hub that I would say is about as solid as anything could be. The bolts that draw the two together will get safety wire run thru them when it all goes together permanently. I will eventually have pics of the whole thing, but will be waiting until I get it off the ground to post a complete start to finish write up on it.
The hub & sprocket was the most costly part of this project at $160, but I would rather spend the money on it than have a large rotor come loose.
  127 Scoop users have viewed this posting.
· valterra's Diary
