| What happens if you concentrate the sun lite on a solar panel? I have a solar collector made from a satellite dish. I can collect more sun rays and send them to a very small area (used for heat only now), It would be like gearing a motor, Would it work or burn up the panel? I'm also thinking about trying solar panels, but the cost is too high. $4.00 per kw. If this would work the cost may be reduce. This ideal would use mirrors. Using mirrors I can and have control the sun light in my garden, it was tested with three layers or stacks. mirrors were used to provide sun to the lower layers. This saved me from using all of my back yard for a garden. The ideal is, I could put 3 panels stacked underground to help with cooling and the lite would not be wasted as it reflects away the energy not collected by the panel. The lower panels can reflect into each other and the sun ray would be used as it moves around the closed solar collector. There would be just one entry point about 2" and my collector would concentrate the lite into the box.
If you think this is crazy I'm used to it. If you can add to it I'm willing to try it. Build it and they will come (that's the energy companies).
Rich |
