| I have a question that has to do with charging batteries in a fictitious 48v wind turbine system. Did some searches here and did not see the answer.
The basic design of an axial flux wind turbine pretty much states that as the turbine spins faster the voltage output increases and is fairly proportional to it's speed. This seems to make a lot of sense to me when you are talking about resistive loads, but I have problems relating this to a system that involves a connection to a battery bank.
For the sake of my example let's assume that all measurements are DC voltages after the rectifier (all voltages are approximate).
Lets say that I have a fictitious wind turbine that outputs the following voltages when connected to a constant value resistive load:
40rpm : 35v
70rpm : 48v
100rpm : 58v
150rpm : 68v
200rpm : 80v
250rpm : 100v
280rpm : 120v
I know that the total power produced will vary with the resistance of the load, and that the output will produce some fairly predictable graph.
Knowing these values we now remove the resistive load and then connect the rectifier to our battery bank, inverter, dump load, etc. (no MPPT controller)
I know that one calculation for power is P = V * I, and I know that the battery bank will 'clamp' the output voltage of the turbine to some fairly constant level (once system voltage is obtained).
I am having trouble getting my head around 'total power output' and how it actually works in the system that contains a battery bank.
Since the battery bank 'clamps' the voltage, as the turbine 'spins up' and it's output voltage increases is this what drives up the amps to satisfy the equation for total power, since voltage can not rise? Or does this 'extra' voltage actually just get lost?
Dan Lenox |
