| The support pole for my mill "failed" late last fall; that bummed me out at bit... The good news is that the mill was working long enough that the boss thinks we saved on electricity (I'm not sure it wasn't mostly conservation) and she has okayed a section of larger pipe to get it back up in the air.
A real tower has been a thorn in my side because there's no place for a guyed tower except in the front yard and that's been vetoed by the boss. Until I can get my self-supporting tower up, I put the mill up a short piece of 2" pipe bolted to the millshed.
I don't recall anyone writing that 2" pipe was good enough to support a 10' mill but I do recall someone writing that they wouldn't even use it for the last few feet... I can say now that using 2" pipe is surely a bad idea.
First real storm we got put a little bend in the pipe:
That didn't seem so bad but it wasn't furling,the angle of the tail assembly was all wrong on top of the bent pipe.
About a week went by without me getting around to it and another storm came along. I woke up in the morning to see the blades rubbing against the top of the millshed. Here's a pic after I strapped the blades to the pipe to keep the mill from turning:
As crashes go, that one wasn't too bad. The worst damage (after the pole) was a little ding in one blade where it hit the roof of the millshed at speed. I'm sort of glad it did find a way to stop itself as it was making well over 50 amps during the storm. I'd wanted to furl around 35 amps so I fretted about the controls (and the alternator) but appears I had enough headroom; everything seems to have survived at least as far as I can test things on the ground.
Insane energy prices have have lit a little fire under me and the boss reiterates her desire to see the mill working again...
I see more people looking at larger mills for heating. I'm personally wondering about a mill running a heat pump; seems like a way to leverage your wind energy by a factor of three or four but am just starting to look into so (as with most topics in RE) I don't know diddly yet...
Cheers,
- Ed.
he measured the pipe and it was only 1.5 inch (not 2 inch) as mentioned at the end of this thread
188 Scoop users have viewed this posting.
