I'm changing the Front Page Poll question every month and it's that time again. The old front page poll was "How are You Making Power?". The results with comments can be seen here. If you haven't voted this question then you can do that here too.....
http://www.fieldlines.com/poll/1211338407_CANnWHjk
I am doing some Addition with the results and here is a summery of the votes from our users...
44% - Wind
48% - Solar
5% - Hydro
2% - Other
24% - Planning a system
The New Poll Question is "What is your Largest Prop Diameter". This poll is not on this page but is found on the lower righthand side of any of the Front Pages
The poll section normally appears on the righthand side of the Main Page (not this page), at the bottom of the Info areas on that side. You must have "Polls" enabled to be able to see them. If you don't see the Polls section then enable them this way...
On the right side of this page find the Menu Box with your Username on it.
Inside that box click the menu item for "Display Preferences"
At the bottom of that page is a listing for "Boxes"
Make sure the "Poll" box is Checked
The front page Poll will now display on all your Main pages.
Helpful Tip:
While you are in "Display Preferences" you should set
"Number of story summaries to show" to 50
"Number of story titles to show" also to 50
This makes the Forum easier to use because 50 story titles will display on the Main Pages instead of only 8 which is the default for new users. |
106 Scoop users have viewed this posting.
