| Having just returned from our place in the North Carolina mountains I am ready to get started on the project that brought me to Otherpower in the first place. For reference, I'm thinking along the lines of the Otherpower project shown here,
http://www.otherpower.com/scotthydro1.html
Here is a short video of the creek I will be working with,
http://s241.photobucket.com/albums/ff74/compoast/?action=view¤t=Waterfall.flv
The water flow is not great but the speed is quite good as the whole slope of the mountain is something like 30% or better. The creek must be spring fed because this area of the Southeast US has been in a drought for sometime. So the flow in the video is on the low side and runs like this or better all year. I would like to do this with as little disturbance to the creek as possible and want to build a small squirrel cage type wheel to suspend in the water at the small falls. Maybe a steel post set in the rock at the bank of the creek with an iron rod like a gate that swings out. 1 or 2 amps at 12 volts 24 hours a day would be just fine with me. I prefer not to do any damming or diverting because my property line is in the center of the creek and I want to stay on good terms with the neighbors should they ever develop their side of the creek.
So, the questions,
Should I build the wheel to the dimensions in the Otherpower link ( the fins being 1/4 of a 4" pipe)and the diameter being 12" or can I improve? (Scott are you reading this?)
And second, building the above design I would like to use PVC pipe for the fins, plate aluminum for the sides, held together with all thread and to keep the PVC in place cast the ends like a magnet rotor. Sound feasible? or,
Is there something out there, easy to obtain that will save me the trouble?
Thanks for reading,
Andy
