AMETEK 50VDC or DIATO 24VDC ?
By barshad, Section Diaries
Posted on Tue Jun 03, 2008 at 04:25:47 PM MST
Ametek 50VDC or Diato 24VDC ?
Which one is better ?
I don't know the details of AMETEK except that is 50VDC,
Details of DIATO is in the Picture.
Please help me to choose the better one.
Best regards and Thanks in Advance,
Bhatti.
One might wonder "better for What".
AMETEK 50VDC or DIATO 24VDC ? | 6 comments (6 topical)
Re: AMETEK 50VDC or DIATO 24VDC ? (3.00 / 0) (#1)
by Norm on Tue Jun 03, 2008 at 03:02:03 PM MST
http://www.tlgwindpower.com/ametek.htm
this link to see what 50vdc Ametek you have...
hope it isn't the NO Good one....
( :>) Norm
Re: AMETEK 50VDC or DIATO 24VDC ? (3.00 / 0) (#2)
by ZooT on Tue Jun 03, 2008 at 11:48:25 PM MST
Geez......I think I'd spin em' both up in a drill press or a lathe and see which one puts out more than the other......and use that one
Re: AMETEK 50VDC or DIATO 24VDC ? (3.00 / 0) (#3)
by barshad on Wed Jun 04, 2008 at 01:38:46 PM MST
Shaft is fat enough and will not fit in drill machine and i have no access to lathe machine, expecting some one technical who can translate/convert rpm, watt. etc. into output.
Thanks anyway for the answer
Re: AMETEK 50VDC or DIATO 24VDC ? (3.00 / 0) (#4)
by ghurd on Wed Jun 04, 2008 at 02:08:00 PM MST
There is no information to work with.
Ghurd.info
Re: AMETEK 50VDC or DIATO 24VDC ? (3.00 / 0) (#5)
by barshad on Thu Jun 05, 2008 at 10:53:00 AM MST
WATTS: 117
VOLTS: 24
RPM: 600
AMPS: 7.5
Re: AMETEK 50VDC or DIATO 24VDC ? (3.00 / 0) (#6)
by ghurd on Thu Jun 05, 2008 at 11:18:21 AM MST
That is information about a motor.  Nothing about a generator.
It may hit cut it at 350 RPM, if you have a 12V system.  And it may never make 12V at under 1000RPM.  It will burn up if it makes more than about 15A for very long.  It may never make 3A.
But that really doesn't help at all, because there is not enough info.
Look through Speo's posts and graphs about Ameteks and Indianas.  V/RPM and terminal resistance.  Whatever else he has posted.
Nothing more than WAGs until it is spun open and loaded, at a few different RPMs.
Ghurd.info
  92 Scoop users have viewed this posting.
· barshad's Diary
