| a simple bit of rudimentary electrical knowledge has changed my insight .
in regards to loading the mill,
in the case of a vawt with five heaters in line,
initially one would want all five in series to create a large resistance
(minimal currant passage )
allowing the mill to start.
as rpm /voltage increases it would be ideal to have the individual heaters drop out of series
and be added in parallel.
(maximum currant)
so what would be the effect on the heaters having two parallel circuits with a different resistance on each.
the line with the greatest resistance would run cooler
this could be problematic
as an alternative
a properly sized resistance heater(allowing the mill to start)
is joined by additional circuits of the same resistance
as the mill gains speed.
am i on track here?
138 Scoop users have viewed this posting.
