| Interesting morning I had. I woke up to lots of noise from my 17' wind turbine (blade flutter). DanF called me on the radio and asked if I needed to borrow a shot gun, he could hear it from his house and knew exactly what was going on. (of course he's kidding, we don't normally shut down wind turbines with a shot gun)
The line down the tower for the 17' machine is quite old, I should've replaced it years ago. It's on a turbulent site so it does twist up quite a bit (usually I untwist it every 3 months or so). It also didn't have very good strain relief at the tower top. A couple months ago the line broke right at the top of the tower - and fell down the tower. Fortunately it shorted itself out and it's just been sitting up there for a while. I've not lowered it yet to fix it for the following reasons:
- I don't really need the power from that machine-
- I lower it with a truck and there's been snow back there (bad traction)
- we've been busy
- I've been lazy about it
For some reason last night (while sleeping) it 'unshorted' itself and took off in fairly high winds! I let it go for about an hour after I woke up to watch it, thinking maybe I'd witness a good crash. It was interesting. The machine was furling still (which is good) but definitely furling late and the load on the tower was quite a lot more than normal. It actually bent the tower above the top guy wires a few degrees.
After consuming a reasonable qty of coffee I brought my truck into position, connected it to the gin pole and let the back guy wires loose. Then I ran around to the other end and tried to pull the tower over enough to overcome the weight of the gin pole - fairly impossible with any wind blowing though due to thrust against the blades, so I had to wait for a calm period. I pulled it over - ran back to the truck just in time to see the wind blow the tower back up into position. We (the tower and I) went through this three times before I finally was able to lower it. In the end it all came out fine but it sure was scary for a bit!
It was encouraging to see it hold together at such extreme rpm anyhow - and it was nice to see that it still would furl under these conditions.
The tower is pretty junky and not really up to a 17' turbine. I'll likely not put this machine back up on that tower. I'll either replace the tower with something more rigid, or test a smaller turbine on it. |
221 Scoop users have viewed this posting.
