| All,
Thanks to lots of info that I have acquired from the people on this site over the past year.
I have a 17' wind turbine that I finally got flying and spinning. Here is the project url: http://www.briery.com/wind_turbine
This turbine is pretty close to the 'original' 17' that the OtherPower.com guys made. Here are basic specs: 48 volt, rotors have 16 - 1.5"x3"x3/4" N42 neo magnets per rotor (there are two 20" diameter rotors), stator has 12 coils with each col having approx 80 turns of #14 wire (about 1.5 lbs copper per coil), connected with 4 coils per phase.
There was a calm 6mph wind (at ground level) so I decided to 'spin' the turbine, I turned on all electronics, unshorted stator and removed the manual brake actuator.
In this low wind the turbine seemed to be spinning at about 60rpm, I could tell as the brake rotor had a 'squeak' to help keep timing.
When checking voltage across each of the 3 phases (I have no neutral) I was registering about 44 volts on my meter, and I am using a Sanrex DF150BA80 3-phase bridge rectifier to convert to DC.
But here is my question: I am registering no amps across the shunt, I would have expected something.
I realize that the wind speed may not enought to bring the turbine up to cut-in speed, but am curious about the 0 amps. Tomorrow I have an backup Sanrex rectifier and will try it in the others place.
Any comments/suggestions? I'm scratching my head.
Dan Lenox |
179 Scoop users have viewed this posting.
