| I'm wanting to set up my mill to charge batteries as an option to my current set up of heating direct. I am conservatively rating my 16' at 3 KW @ approx. 100 VAC 3 phase star. I'm planning on a 48 VDC bank with a nothing cheap inverter and dump load at full charge.
My questions are : Is there a minimum safe capacity for my battery bank ? If the rectified voltage is 1.4 x the AC this means it's possible I could see 140 VDC ? Am I figuring this right ? As is now I measure approx. 35 VAC per phase @ 105 RPM. If this is times 1.4 this gives me approx. 50 VDC. So if I'm figuring this right I would hit cut in at near 105 RPM.
Fully furled now is limiting output to around 100+- VAC @ approx. 300 RPM with my direct load of (3) 4500 watt 240 VAc heating elements wired delta, (alternator is star) This figures to around 3 KW output.
Back to my original title question : Other than an ammeter in series with the charging circuit and using ohms law is there any way to know what the battery resistance is at different voltages ? Any help or suggestions would be appreciated. Thank you Dave B. |
157 Scoop users have viewed this posting.
