| Here is a peek at the Alien PTV 3 wheel project.... Scratch built with the exception of the S10 spindles and brakes ( wheels of course ). This is 6 weeks into the project starting with an idea and a pile of steel....
Alien... because it looks kind of weird and I'm a bit of a SCIFI nut ... PTV because it is a "Personal Transportation Vehicle"
The front suspension incorporates some Harley coil overs with 300 lb springs mounted inboard for space, the rear has a single sided swing arm with an over wheel spring system because of the limited space. The motor is a D&D 10 Hp continuous, 40hp peak. Batteries are the Optima D31 deep cycle AGM chosen to keep the weight down. Altrax controller, reverse contactors and chain drive using a 5 to 1 ratio.
I have some finish welding to do, brackets, steering and misc then its comming appart to be painted piece by piece. I plan a body for it but it won't be until winter when I start fabricating for this. I'm planning a "1 off" foam and fiberglass sectioned panel body for it. I'm considering removing the overhead bars and building a tilt up windscreen section that will fully enclose the unit for extended season use.
I'll be adding a page to my site for the project in the near future...
151 Scoop users have viewed this posting.
