I have made a few stators using plywood. Works well, but I would like something more durable.
At the Guemes Island workshop last year I liked your HDPE molds.
I called the local plastic company, and they want $330 a sheet for 1/2" HDPE.
I was thinking of maybe making the mold from steel instead. I have some here.
Do you see any problems with this idea?
Thanks[ Parent ]
Unless you are going into large scale production I can't see it being worthwhile.
Polyester virtually sticks to nothing and will be easy. I have no experience of vinyl ester but it shares many properties with epoxy. From experiences at work years ago, epoxy released well from cold moulds as long as the surface finish was near perfect. WE had need to hot mould some epoxy items and these were a real pain to release especially on new moulds. In desperation we heated some of the moulds to blueing temperature and the oxide formed helped considerably.
Flux[ Parent ]
Any thoughts on using steel with a good mold release instead of hdpe?[ Parent ]
Search for UHMW or HDPE
Where can I find pictures of one of these? I have a machinist that has volunteered to do my millwork, I just need to figure out what I really want.[ Parent ]
Ron Adventure is just bad planning." -- Roald Amundsen
The "puck board" name may not be as common in the US as it is here. Up here, in the bleak frozen wilderness of Canada, we have lots of hockey arenas. All of them are lined with this cheap plastic sheet. Steven Fahey
Thanks![ Parent ]
