Jacobs serial number
By bb, Section Wind
Posted on Mon Jul 21st, 2008 at 02:38:49 AM MST
Looking for information on Jacobs date of manufacture
Jacobs Model: P1582  Serial Number: 98EBB20  429346MH
Blades: ABGBVT  Gear: 12 degree long shaft spiner  Tail: Dual Fold
Wood Blades: 23ft.
Does anyone have information on serialization of these units/ date of manufacture?
I found this one abandoned and am looking for information on it. I have the ability to connect to a net metering system at my home, and am paying 9.5 cents per kwh. The system does not have a grid tie inverter. Are parts available for these? What would it cost to replace the blades? Can a larger swept area be applied to this unit to increase output? What is the value of a standing system of this vintage, considering it would need removal and re-installation?
Any internet sites recommended for information if not available here?
Thanks,
B
Jacobs serial number | 5 comments (5 topical, 0 editorial)
Re: Jacobs serial number (3.00 / 0) (#1)
by dnix71 (yahoo.com 'dnix71') on Sun Jul 20th, 2008 at 09:02:11 PM MST
Is yours the old style or the new?
http://www.windturbine.net/products.htm is the current manufacturer, and according to an online encyclopedia, the originals were in use from 1930 to 1960.
http://original.britannica.com/eb/topic-299096/Jacobs-three-bladed-windmill
Re: Jacobs serial number (3.00 / 0) (#2)
by bb on Sun Jul 20th, 2008 at 09:06:29 PM MST
I believe it is probably circa 1980's.
Re: Jacobs serial number (3.00 / 0) (#3)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Sun Jul 20th, 2008 at 09:47:55 PM MST
Short answer
Longer blades = less power
Long answer
If you put longer blades on it, then it will spin slower and it will not be able to produce it's rated output
W o o f -={(
Re: Jacobs serial number (3.00 / 0) (#4)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Sun Jul 20th, 2008 at 09:52:07 PM MST
I posted that without reading it, I said "Longer Blades = Less Power".
What I should have said is, If you put longer blades on a machine designed for smaller props, it will make less power because it will spin slower with the longer blades reducing the output voltage.
so that was the long answer . . .
W o o f -={(
Re: Jacobs serial number (3.00 / 0) (#5)
by DanB (danb@*no spam*otherpower.com) on Mon Jul 21st, 2008 at 03:56:02 PM MST
Hi woof - yes that is usually the case, I'm not sure it's always the case for this particular machine though.  I could be wrong, but I think the big jacobs machines do come with blades varying quite a bit in size and I think the only difference between them is the rated output, the blade diameter, and the inverter (I think... ).  I dont think the generator, or the gearing is different in them (which does seem a bit odd)
  98 Scoop users have viewed this posting.
· Also by bb
