Hi to all.
I recently found an article, which started me thinking. The bottom half of the article is what caught my attention.
http://www.popularmechanics.com/science/earth/4232571.html
I'm hoping to get some thoughts as to whether the concept of using a heat source to vaporize a refrigerant, which drives a turbine, is condensed, and returns to the heat source, within a closed loop might be practical way of generating electrical power.
The heat source might be a storage mass surrounding an outdoor wood furnace.
The turbine might be a turbocharger, as in the article, or possibly commercial refrigeration compressor, or other salvaged components be used to drive an alternator.
The vapor might be condensed by air, or water and returned by gravity, or a small pump?
An output of 1 - 3 KVA would be very desirable. It might be useful to have the combined output of 2 or more units produce the power output I would like to achieve. The inefficiencies are likely to be horrendous, but with a large supply of free fuel, that might be o.k.
Building this system would be a combination of DIY, and buying the parts and services I can't supply. There are lots of salvage yards, refrigeration shops, and even a couple of shops that rebuild pumps, and electrical motors in the area. I don't mind spending some money, if the idea can be made to work.
Any thoughts or suggestions, including constructive criticism will be greatly appreciated.
Thanks in advance
Pete |
83 Scoop users have viewed this posting.
