| I'm posting this for Danish wind power guru Claus Nybroe of Wind Mission, at his request.
In short, a patent has been granted for a system that has been in use for years. Claus was recently informed that his new turbine could be in violation. Anyone that remembers the Kenetech variable speed inverter patent fiasco of a few years back would agree this kind of use of patents is very bad for the entire industry. The deadline for getting some proof that these techniques have been used before is the end of August.
Here's the patent:
http://www.google.com/patents?id=eekUAAAAEBAJ&dq=6911741
Here's whats needed:
- pre-october 2000 photos of testing a wind turbine alternator using a lathe:
From Claus: "What Scanwind claims in their patent, is what a lot of us has been doing
many times, when testing PMG's or other generators: Mounting the generator
shaft in a lathe while fixing the stator house and measuring torque with a
spring or load cell equipped torque arm."
-Or, pre-october 2000 photos of this commonly used mounting system:
"The PMG rotor is connected to main shaft. The stator (housing) is locked
against turning by a non-rotable coupling or torque arm/reaction support
which: (Patent quote): "... transfers substantially no bending or axial
force against the flexing of the turbine shaft due to the bending moment
acting on the turbine shaft from its hub ..." The coupling can the be
connected to machine frame or other non-rotating part."
If you can help Claus, contact his directly at his website,
Wind Mission
Thanks!
ADMIN |
198 Scoop users have viewed this posting.
