| Hello all Just checking to see if there is a way to check to rpm on my turbine while also being able to see the amps and voltage at the unit, I have meters on the amps and voltage, I am charging a bat. bank of 12- 2 volt bat. at 12 volts and the rectifiers are dwon at the bat. And with that is it better to have the Rectifier at the bottom of the tower or at the Top ?Thanks |
195 Scoop users have viewed this posting.
