| I'm expecting new batteries today so I want to look after them. To this end I want to make sure that I don't over charge or discharge them. My controller is presently the simple 555 comparator circuit which I believe will do the job provided I can work out what assumptions are made when lead acid cell charge/discharge curves are published.
For example, I've seen many tables/graphs of cell voltage against state of charge but these are (presumably) plotted by charging, resting and then measuring voltage. How does this change if I'm measuring voltage whilst charging. The same goes for discharge.
The new batteries are 2 strings of 4 T105 equivalents for a 24volt system so I was going to start out with a full charge voltage of 28 volts and max discharge at 22 volts - the idea is to keep in the top 30% of full charge. Do these values look reasonable or should I start out with values closer to the nominal 25.2 volts (i.e. 2.1 volts per cell).
I could be living in interesting times!! |
89 Scoop users have viewed this posting.
