| Walked past my battery array today - as I do probably 10 times a day.... however something caught my eye... I stopped and looked more closely, hardly believing what I was looking at!
When I put my second PV bank in place, I had replaced the older, smaller screw connector block with a larger one. At the time, I didn't have any of my preferred ceramic block types, so I used some large, "60 amp" nylon ones. Heck, all my panel can provide is a little over 12 amps at 48V, so 60 amps would eat it anyway.
Last time I looked at this closely was not that long ago, but today was... well, judge for yourself how close it must have been!
and
I quickly replaced the whole lot, and recovered the connectors for a closer investigation.
So I then set to with a knife and cut away some of the melted nylon to see just how close I got to a big "bang"....
LOOKS to be actually touching - but isn't, because the metal body of the left-hand connector is on an angle...
but it's VERY close!
I will try to pull it apart later to find why - I don't believe the screw was loose, but it may have been. Obviously SOMETHING was high-resistance.
The real danger this shows is that although there are fuses to protect the panels and wiring on the "panel" side of this connector, and the batteries have a huge fuse, I don't think there is "suitable" protection for this fairly light wiring because it never ocurred to me to me that these connectors could/would fail in this manner.
Glad I caught it in time - and hopefully someone else can learn from this close call!
182 Scoop users have viewed this posting.
