Generator and Deep Well submersible
By pepperhead1963, Section Newbies
Posted on Fri Aug 22nd, 2008 at 12:52:30 PM MST
10/3 over 40 feet?
I had my electrician put a 220v male outlet outside my house and in the basement he has to female outlets, one for grid and one hanging that goes outside to the previously mentioned outlet. In event of power failure, I start up my genny, which is 6000 watts, not sure what surge is, them plug in cable to wall for pump.
So my question is, is 40 feet of 10/3 good enought and I assume that I should start the genny first, let it run a while then run water in house as per normal
Anything I am missing?
Generator and Deep Well submersible | 9 comments (9 topical, 0 editorial)
Re: Generator and Deep Well submersible (3.00 / 0) (#1)
by pepperhead1963 on Fri Aug 22nd, 2008 at 06:53:35 AM MST
Apologize for triple posting...
Re: Generator and Deep Well submersible (3.00 / 0) (#2)
by TomW on Fri Aug 22nd, 2008 at 07:17:56 AM MST
1963;
I closed the other 2. I will remove them now since you see you did it 3X.
No worries.
Re: Generator and Deep Well submersible (3.00 / 0) (#3)
by wpowokal on Fri Aug 22nd, 2008 at 11:02:57 PM MST
I sugest you look up one of the many voltage drop calculators, as 10/3 means nothing to me.
http://www.cse-distributors.co.uk/cable/voltage-drop.htm
allan down under
Re: Generator and Deep Well (3.00 / 0) (#4)
by wpowokal on Fri Aug 22nd, 2008 at 11:39:01 PM MST
As you don't tell us what the power rating (voltage, HP/Kw) is of your pump and not knowing what 10/3 is, it's anybodys guess.
Try these voltage drop calculators or google for others.
allan down under
Re: Generator and Deep Well (3.00 / 0) (#6)
by TomW on Sat Aug 23rd, 2008 at 08:11:06 AM MST
Allan;
Well, I happen to understand the 10/3 part, at least.
Thats a cable that has 3] #10 insulated conductors in one sheath. Often with a bare ground of #10 in the bundle.
Very common for feeding 240 volt circuits here. Stuff like pumps, welders and electric water heaters.
Re: Generator and Deep Well submersible (3.00 / 0) (#5)
by jonas302 on Sat Aug 23rd, 2008 at 07:42:42 AM MST
see if you can read the size on the wire to the well if you can get at it if your bigger than that you should be good
Re: Generator and Deep Well submersible (3.00 / 0) (#7)
by kurt on Sat Aug 23rd, 2008 at 06:32:38 PM MST
10 gauge wire is usually considered good for 30 amps in home wiring i am quite sure your pump doesn't draw anywhere near 30 amps at 240v so you should be good.
http://www.reresource.org/
IRC
Re: Generator and Deep Well submersible (3.00 / 0) (#8)
by pepperhead1963 on Mon Aug 25th, 2008 at 09:41:43 AM MST
I had an electrian come in and he made me a cable, it turned out to be 10/4
Thanks all
Re: Generator and Deep Well submersible (3.00 / 0) (#9)
by wpowokal on Mon Aug 25th, 2008 at 06:12:16 PM MST
So it was a 3 wire motor ie it has a starter box.
allan
  56 Scoop users have viewed this posting.
· Also by pepperhead1963
