High speed turbine
By tecker, Section Diaries
Posted on Sun Aug 24th, 2008 at 07:25:35 PM MST
 Looks like a car Vawt
I 'm tearing this unit down one more time for a grinding and painting . Installed just behined the front bumper I takes off at 30 mph and is quiet enough at 75 I don't hear it at all I neeeded higher  voltages for the HHO Cell to get the volume up with distilled water . I thought it looked so much like a Vawt you'd get a kick out of scaled down 120 degree blade configuration.
The stator is tapped 6 times at 20 and 30 ohms per . It runs 10 to 75 volts around 1 to 1.3 amps per tap . The taps are rectified and paralleled and series in over battery voltage  . The cell is on a lawton pmw at 2. 5 to 4 amps(when it gets hot ) with good volume .
High speed turbine | 7 comments (7 topical, 0 editorial)
Re: High speed turbine (3.00 / 0) (#1)
by tecker on Sun Aug 24th, 2008 at 01:28:24 PM MST
Here's b side
Re: High speed turbine (3.00 / 0) (#4)
by tecker on Sun Aug 24th, 2008 at 02:46:25 PM MST
Thats pwm . Man!
Re: High speed turbine (3.00 / 0) (#2)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Sun Aug 24th, 2008 at 02:23:13 PM MST
Do you have any pics of the PMA or the gen guts before it was covered?
Re: High speed turbine (3.00 / 0) (#3)
by tecker on Sun Aug 24th, 2008 at 02:39:09 PM MST
 I'm taking the gen down for varnish and paint I'll take some.
Re: High speed turbine (3.00 / 0) (#5)
by tecker on Tue Aug 26th, 2008 at 07:04:24 AM MST
The rotor and stator .I screwed up the wire hauling it around a mounting it in diferent places . Replace that  urethane the stator and several coats of pint and a sealing disk on the mounting side
Re: High speed turbine (3.00 / 0) (#6)
by tecker on Tue Aug 26th, 2008 at 07:08:34 AM MST
 Stator I hit the wong button
Re: High speed turbine (3.00 / 0) (#7)
by electrondady1 on Fri Aug 29th, 2008 at 07:02:22 AM MST
hey tecker ,
i had to do a bit of you tube research to figure out what your post was about .
nice use of a cieling fan/savonius
does the  pwm work with various input voltages?
· tecker's Diary
