| Hi
I've installed the rectifiers for my wind turbine and the S4w charge booster in a box which used to be a marine battery charger.
The box already has a nice little 12V fan. I'd like the fan to start automatically when the diodes start getting hot. Any ideas? Whatever I use needs to be relatively small to fit inside the box.
I've looked at a few cheap thermostats, but they all have NC contacts rather than NO. I don't want to use any kind of electronic control which would consume power when the fan is not running. The energy consumption of the fan (and relay?) when they are needed would not be a problem. If the box is hot, that means the wind turbine must be pumping out some juice, so I can spare enough to run the fan to keep things cool.
Owen
