| ok,
I have just had a frustrating couple of hours figureing out why my ADSL connection wasn't working.
I'm still not entirely sure why
I only got an ADSL connection a couple of weeks ago and have just been running my small 350watt inverter and everything was fine.
Yesterday I discovered 1 battery to be a third to half a volt lower than others(see storage section post) so I temporarily changed over to a backup battery bank which has my big(ger) inverter on it(1500cont.). This inverter has a ground connection on the back and manual instructs to connect wire to a grounding like pipe etc going into the ground. Next to where I have my batteries and inverters etc setup under the house there is a metal pipe sticking out of the ground just outside which had holes drilled in the top and a short piece of wire hanging fromit. I assume(d) that this was the ground connection made by previous owner so I hooked up that to the ground connection on the inverter.
After changing over to that inverter/backup bank I noticed last night the ADSL connection was no good(no internet and DSL light on modem flashing red)
This morning, after checking with ISP to see if fault was thier end(another saga alltogether involving indian guy who can't speak english properly...) I then proceeded to attempt to isolate the cause.
After much drama and cursing I rounded the problem down to 2 things:
1 AUSTAR satelite TV was interfereing, as when I powered off the TV and AUSTAR box the internet connection came good.(I repeated this several times to confirm)
After giving further thought I realised this had never been a problem before so it must be something else as well.
2 The big inverter. Iswitched back over to the other small inverter and battery bank and then every thing was fine(internet and AUSTAR could both work at same time)
With everything working properly running through small inverter I then powered on the big inverter(with nothing plugged into output) and sure enough, the internet connection dropped and DSL light on modem went red.
Last of all I removed the ground wire from the big inverter and then everything went good again.
I now believe the problem is a combination of the AUSTAR satelite TV and the grounding of the big inverter.
The phoneline is underground and comes to the house on the opposite side of where the inverter/batteries etc and ground pipe are.
Question:
Does the inverter REALLY NEED a ground wire?
If so how should I do this properly?
Has anyone else had similar issues and how to resolve?
Obviously, for now I'm running the small inverter as it doesn't have this problem and I don't want to run the big inverter without the ground wire in case it cooks something.
<sigh>
Any comments suggestions appreciated,
Ian.
77 Scoop users have viewed this posting.
