| I have been dreaming and making calculations for systems of varying sizes, trying to decide just how large I want to go right now. I'm not interested at this point in going whole-house or grid-tied, as this is primarily an experimenter/playtoy thing for me to have some fun with.
My dilemma right now is what battery bank voltage to go with. My primary daily use for the system is going to be my ham shack, where ALL of my gear is 12V. Radios, scanners, even amplifiers. For that matter, a lot of my networking gear is 12V as well. I also have a fair collection of 12V lighting in the form of RV fluorescent lights and some modified LED drop lights that I can use for "emergency lighting" in case the grid goes down.
The problem, though, is that I would also like to have sufficient capacity in the batteries to run "essentials" in an outage (primarily the refrigerator). This could primarily be an issue with battery-bank sizing, as I don't necessarily need to be able to run everything strictly off solar, nor does it need to run all day. I do have a generator, which could run the appliances directly, but could also be used to provide bulk charging to the battery bank. I just don't want to have to run the generator at night or when I'm gone, but would like the food in the fridge to keep!
So at what point (wattage or otherwise) does it simply become infeasible to stay with 12V? I certainly don't need to stay there, as I could just run the rigs with the power supplies I already have, that just seems a bit wasteful - and might push my inverter requirements up higher than I'd like. On the other hand, I notice most if not all the higher-wattage components (panels and inverters in particular) don't come in 12V anyway.
I have had some people mention pulling off just a portion of the battery bank for 12V items, but I'm worried about unbalancing the battery charges that way. I have a fairly sizable draw, especially when I'm actively using the rigs and not just listening, and as I mentioned before this would be the primary use for the system.
Some usage numbers for the primary loads, in case they help:
Ham bench would be around 50AH (at 12V) per day. That is, nominally. Certainly in a pinch I could greatly reduce that. And if I was having a really active weekend it could go significantly higher. (Another reason an oversize battery bank wouldn't necessarily bother me!)
Refrigerator pulls around 110W while running. The Kill-A-Watt shows an average of 1.6kWh/day usage. But this would be an outage-only load, and I could be recharging the batteries with the generator part of the day. Primarily I just need enough AH in the batteries to run this.
158 Scoop users have viewed this posting.
