| Like many folks here I use those cheap Harbor Freight digital multimeters. I have found them to be fairly accurate when compared to each other and to my other analog meter. So far I have ruined 3 of them by trying to measure volts with the leads still connected to measure current or other stupid mistakes. At $2 a pop it's no big deal but I hate waste and so want to hardwire them into my bank where I don't have to mess with them. Also, changing the 9 volt battery costs more than the meter.
The question: Will a 4700 ohm resister be the best choice to run this 9 volt meter off my battery bank which varies in voltage from 12.4 to 14.8 volts? I did a quick test and with my bank sitting at about 13 volts and using a 4700 ohm resister it showed the voltage across the meter at 9.6 volts with the meter turned on and working ok.
Thanks, Andy |
92 Scoop users have viewed this posting.
