I have recently acquired a whole house fan for free but, would like to know where I can get a low amp draw 12 vdc motor to replace the 6.6 amp draw, 120 vac motor.
The fan blades, of which there are 4, measures 43 inches in diameter and have about a 35 degree pitch. Belt driven.
Again, it will be powered from an off grid 12 volt nominal, 1600 amp hour battery bank, 1,000 watt PV array charging system. So, I need a motor that draws as little amperage as possible but can still move 5,000 cubic feet of air on a regular basis. The plan is to build a squared "cupola" on the roof that will house the fan and motor, while the ceiling grate (which opens with negative pressure) is of course mounted in the ceiling, thus pulling air from both from the interior of the house and the attic and venting directly outside by way of louvered vents (much like gable vents) all the way around the "cupola."
I have looked at some 12 vdc motors that draw around 20 amps (which is at the top end of what the system can afford amperage wise) but I am not sure if it will do the job. Would like to see less amperage if possible.
I have all ready thought about such things as insulation being "sucked up" and believe that to be a minor hurdle to overcome with a low density fiber cloth similar to a house wrap, that will allow air to pass through but not insulation fibers. Also, I am not against using a small 12 vdc actuator to open the ceiling grate if necessary.
Thank you for any assistance. I know this is a tall order, given todays motor technologies. If amperage where not the biggest hurdle, it would be an easy choice of which motor to use.
Sincerely, Sunour. |
