I'm mid-way through building myself a wind-turbine. Once I've proven I can generate a useful amount of power I plan to buy a Windy Boy grid connect inverter. Trouble is I don't know how many turns to use in the alternator. There's loads of information about 12v battery charging systems but much less about driving inverters.
Background:
3.2m blades, TSR=6.
300mm diameter alternator. 2 discs, 12 magnets per disc.
Magnets are 2x1x0.5 inch N40.
Air gap currently 19mm.
I've wound a 10-turn test coil and taken some measurements with a 'scope:
Measured Measured Measured Calc Calc
Hz Vpp Vrms RPM Vpp/RPM/Turn
5.35 0.59 0.195 26.75 0.0022
6.15 0.60 0.201 30.75 0.0020
10.61 0.98 0.344 53.05 0.0018
11.86 1.12 0.381 59.30 0.0019
16.89 1.64 0.532 84.45 0.0019
18.00 1.72 0.587 90.00 0.0019
19.40 1.84 0.635 97.00 0.0019
23.30 2.16 0.737 116.50 0.0019
24.60 2.32 0.732 123.00 0.0019
26.80 2.60 0.904 134.00 0.0019
29.90 2.72 0.980 149.50 0.0018
33.80 3.24 1.110 169.00 0.0019
42 3.88 1.390 210.00 0.0018
I've tried to calculate the number of turns...
Say 0.0019 Volts peak-peak per turn per RPM.
Windy boy 1700 spec says:
Vmin 139
Vnom 180
Vmax 400
Turbine is 3.2m => 10m circumference, TSR=6, hence at windspeed 3.5m/s:
rpm = (3.5 * 6 / 10) * 60 = 126
Hence for Vmin at 126 rpm:
turns = 139/(0.0019*126*3) = 194
(Times three is because I'm assuming 3 coils in series per phase.)
What worries me is that Hugh Piggot suggests 70-90 turns for a 12v system so I'd expect to need ten times that number!
What am I missing? Resistive losses in the coil? Ripple after rectification?
All suggestions welcome!
