Lessons Learned
By luv2weld, Section Diaries
Posted on Thu Sep 25, 2008 at 02:03:23 PM MST
Things I learned the hard way in the last 2 years
One of the things I learned was----the typical yaw bearing
(pipe over pipe) without something to spread the weight and the
wear is not a good idea. I've seen other postings here that confirm
that. It doesn't take long for the end of the pipe to wear through
the flat plate that's supporting the weight of the generator head.
My solution is a 4 bolt flange bearing. Add a couple of pieces of
angle onto the bottom of the yaw so that the bearing has a flat
surface to bolt to.
Set the bearing so that there is a clearance of 1/4 to 1/2 inch
(6 to 12 mm) between the end of the pipe and the flat plate stopper.
Paint a white line around the tower stub at the point where the bottom
edge of the bearing will sit. The white line will tell you if the
bearing has slipped and the pipe is once again rubbing on the flat
plate. It's visible from the ground, so you will know without having
to lower the tower and check.
The next thing I learned was to install a grease fitting on the side
of the yaw bearing. I tried greasing the tower stub and then slipping
the yaw over it.
No matter how I tried, I always  ended up scraping half the grease off
with the end of the stub. The simple solution is to install a grease
fitting (or 2) during the building of the yaw. Put the yaw on the stub
and pump the grease gun until your arms hurt. You don't end up looking
like a greased pig! I don't have a picture of the grease fitting.
The lesson that really hurt was the one that cost me a set of blades.
The tower stub needs reinforcing where it meets the tower. My tower
is 4 inch black pipe. The stub is 1 1/2 inch  black pipe. It never
entered my little brain that it would need bracing. The end
result can be seen in these pictures.
The stub was constructed of 2 large washers and the 1 1/2 inch pipe.
One washer, welded to the bottom end of the stub, slid into the 4
inch pipe. The other washer, about 18 inches up the stub from the
first was welded to both the stub and the top of the 4 inch pipe.
I just knew that was a very secure joint!!!  Wrong!!!!!!
Here is a picture of the broken stub after it was cut from the
top of the tower.
I now know that you either need some triangle shaped braces or
another piece of pipe inside of the tower stub.
At the time mine crashed, I didn't have any 1/2 inch thick plate
to make braces, so I opted for putting a piece of 1 1/4 inch pipe
inside the 1 1/2 inch tower stub. Those 2 pieces are welded together
on each end. Then the washers are slid over the 1 1/2 inch pipe and
welded into place. Then the whole assembly is slipped into the 4 inch
tower and welded.
That way if the 1 1/2 inch stub cracks and breaks where it
meets the tower, I will have a little help from the inside pipe. It may bend, which is
my warning that something is wrong. That way I can lower the tower and fix it .
Hopefully without destroying my blades again.
I hope these things will inspire others to show the lessons that
they have learned.
Maybe  we should have a section titled "Things I Learned the Hard Way!!
Ralph
Lessons Learned | 19 comments (19 topical)
Re: Lessons Learned (3.00 / 0) (#1)
by thirteen on Thu Sep 25, 2008 at 08:19:41 PM MST
At work we have bearings that are to high to reach easily so we put a platic grease line down to where it is easy to get to. No 1 grease cold weather no.2 grease warm weather. Something this might work the $$ is fairly cheap and they can be made flexible. The line won't go 360 but could come close. Just an idea.
Re: Lessons Learned (3.00 / 0) (#2)
by richhagen on Fri Sep 26, 2008 at 12:47:13 AM MST
luv2weld, I think posts like this are among the most educational posts, because they show the results of things that can go wrong and propose solutions.  I would have though nothing bad of using a tower stub of the design you originaly had.  I am guessing that the heat of welding made the pipe more brittle next to the weld as well. Thanks for sharing.  Rich
Re: Lessons Learned (3.00 / 0) (#3)
by richhagen on Fri Sep 26, 2008 at 12:53:59 AM MST
One other note on the bearing.  I have some similar appearing flange bearings, and if I recall correctly the rated load parallel to the axis of rotation was only 15 percent of that perpendicular to that axis.  I wonder about how long they will hold up under this type of loading.  I know DanB had some thrust bearing designed to take loading in that axis, and I had wondered about tapered roller bearings for a yaw type of application because a pair of them should be able to handle a fair bit of loading both perpendicular and parallel, although I don't recall off hand seeing anyone using any for a yaw bearing, and the cost for the sizes required might be prohibitive.  Rich
Re: Lessons Learned (3.00 / 0) (#4)
by Flux on Fri Sep 26, 2008 at 02:56:36 AM MST
Radial bearings are not intended to support much in the way of axial thrust but in these conditions they should be perfectly adequate, the thrust loading is not high for the large size of bearing.
Thrust races are ok as are angular contact ( expensive solution) I tend to use taper rollers to support the weight and keep things centred ( which ball thrust bearings won,t do easily).
On the only machine I have fitted with a full set of slip rings I used taper rollers top and bottom but the lack of frictional damping makes it rather inclined to wag around in turbulent winds.
I agree with something to take the vertical thrust and tend to use a taper roller at the top, the rest is sort of pipe on pipe but with a plastic or Tufnol ( Resin bonded linen) bush at the bottom end although most of this comes from my engineering background, as long as you keep grease in there plain pipe on pipe will last for many tears.
With any form of ball or roller bearing in these set ups it will work as long as you keep grease in and water out. If the thing starts to rust it will be no better than a steel plate sitting on the end of a pipe and may fail sooner.
Re: Lessons Learned (3.00 / 0) (#14)
by harrie on Sun Sep 28, 2008 at 03:10:31 PM MST
Rich. My 22 foot duelrotor has had the taper roller bearings in it now for over a year. The turbine weighs in at over 500 lbs and has never had a problem, and I dont expect one. Photo below is had to see, but has a bearing at the top, and another one at about 16 inches down. The only thing is that it turns so freely that the turbine will yaw back and forth with turbulance which i wasnt too fond of, so I installed a spring loaded pin with a hole flange to hold it into the wind. the pin is operated with a 1/8" cable from the bottom of the tower. Those of you having trouble with furling may want to try this, cause it will not let the turbine yaw while furling. A picture of this is also below.
Re: Lessons Learned (3.00 / 0) (#5)
by jlt on Fri Sep 26, 2008 at 10:56:04 AM MST
I have  had the same problem  of not turning  very easy it worked well for 6 months. and now will not turn into wind until it's very strong.I'm trying to find a throw out bearing to fit inside a 3 1/2 inch pipe .
Re: Lessons Learned (3.00 / 0) (#6)
by Dave B on Fri Sep 26, 2008 at 12:01:00 PM MST
I have a 16' and ran an 18' also with a thick bronze washer I cut to fit at the tower top. The pivot top and of course the stub top are welded steel plate with the cable hole bored, this gives the flat surface area for the large washer (bushing) to be sandwiched. Make it as close to the pipe diameter as you can and if you have a decent slip joint of pipe over pipe with minimal slop then all greased up works fine. I favor the bit of friction to yaw the machine, I'll check and grease it during the regular inspection but from what I had seen before this makes a very good thrust bearing. It actually seems to get better with time with a very smooth surface and very little sign of wear, not a concern for me with close to 250 Lbs of machine up there. Dave B.
Re: Lessons Learned (3.00 / 0) (#7)
by DanB on Fri Sep 26, 2008 at 12:47:26 PM MST
Yes, I have to agree with Dave...
a thrust bushing/bearing at the top is necessary - especially on turbulent sites, although I know some folks have gone for years with nothing like that - it always fails here (its turbulent here).
A good pipe over pipe yaw bearing is OK though, so long as it's greased - Dixie posted recently about their failure with the 15' turbine, the yaw pipe did wear out, but it took 4 years with no maintenance and Im afraid the machine was built very ligtly (I'd use much bigger/longer pipe for the yaw these days).  Some friction is nice there I think.  Although - you're solution with the bearing looks workable.  I worry a bit that if the bearing fails it could prevent furling - a very simple/sturdy pipe over pipe arrangement should never seize even if it wears out badly ~ so long as there is a bushing at the very top.
Not sure if this is a 10' machine or not - but - if it is, I think also part of the problem with teh stub snapping off is that its too long.  The stub should be just about the same length as the yaw bearing itself, looks like this one is quite long, and 1.5" pipe is not strong enough to support a machine that large in my opinion.  I'd not have less than 2.5" sched 40 pipe from the top guy wires to the yaw bearing itself - then a smaller pipe for the stub would be OK.
Re: Lessons Learned (3.00 / 0) (#8)
by cdog on Fri Sep 26, 2008 at 08:59:53 PM MST
I think your'e on to something!!!!
Cdog.
Re: Lessons Learned (3.00 / 0) (#9)
by Ungrounded Lightning Rod on Fri Sep 26, 2008 at 09:05:10 PM MST
Two comments:
1) If you have a single yaw bearing it should be about as high as the center of effort of the turbine's drag, i.e. near the turbine axis.
This is especially true when the bearing is narrow and a press fit on the mounting pipe:  The drag of the wind is applied via a lever arm corresponding to the distance between the center of effort of the wind from the bearing.  As the wind varies the shaft wiggles back-and-forth in the bearing - eventually working its way out.
With two bearings placement is not so critical.  The leverage turns into side thrusts in opposite directions (both below or both above the center of effort) or in the same direction but at possibly different strengths (one below and one above).  The "tapered yaw bearing above the turbine axis, pipe-over-pipe below it" approach is such a two-bearing situation.
2) The narrower a pipe (or other beam), the weaker it is.  Your two-inch pipe inside the four-inch pipe is much weaker in bending than the outer pipe and prone to falilure.  And it did fail - at the maximum bending-stress point (at the upper ring).  You should have used two large pipes, not one big and one small.  Or done the reduction immediately below the yaw bearing (with the latter about the height of the turbine axis).
Re: Lessons Learned (3.00 / 0) (#10)
by cdog on Fri Sep 26, 2008 at 09:14:51 PM MST
I used a piece of 2" shaft, turned the ends down and used 1-15/16 bearings, and bored a hole 1" through the center for the wire to go through.
No problems so far, been up since february,
Cdog.
Re: Lessons Learned (3.00 / 0) (#11)
by luv2weld on Sat Sep 27, 2008 at 08:16:25 AM MST
Thanks to all who have taken the time to read and respond to
my ramblings.
I will attempt to answer the responses so far in this one posting.
I used what I had on hand for the tower and generator.
I had the flange bearing in the barn, so I used it.
The pipe in pipe was used because it was a quick fix and I had it on hand.
I also think the 1 1/2 inch pipe is too small.
And the stub is too long.
All these corrections are on the list of things to do. But as
most of you know, it takes time to get to these things.
Have been looking for larger pipe for a while now. I only go
to town about once a month, ( and to the big city about once
every 3 months), so it takes a while to find salvage steel and pipe.
I have been thinking about the thrust bearing concept as mentioned
by DaveB and DanB. What I was thinking was using a thick piece
of HDPE (1/2 inch or so) as the washer instead of brass. Our
Canadian friends call this puckboard.
Has anyone already tried this????
Ralph
Re: Lessons Learned (3.00 / 0) (#12)
by electronbaby on Sat Sep 27, 2008 at 09:11:20 PM MST
Ive never used HDPE, but I have used a 1/2" thick teflon bushing and it works great. I use it on all my machines now. I grease it as well. I welded up an insert out of stainless that fits into the top of the tower stub snuggly, and the upper surface is machined and polished. Then I lay on the teflon bushing and slip the yaw tube down over it. There are 1" holes bored through the stainless insert, the teflon bushing, and the top of the yaw tube where the feed line passes through.
Ive never had a problem. Teflon can take the compression that a heavy machine will give you. HDPE will not. Its too soft in my opinion.
Have Fun!! RoyR KB2UHF
Re: Lessons Learned (3.00 / 0) (#13)
by tmcmurran on Sun Sep 28, 2008 at 10:48:14 AM MST
The fracture could have been excelerated by the heat from the weld at the collar.  I have done pretty much the same, but placed a good three to four feet inside the larger section filled with cement.  Makes for a very heavy tower, but has removed all vibrations.  I am in the process of moving this tower, and once I head back out to the house will take a few photos.
But I do agree that extra support from the upper and lower portions can never hurt.  The stonger your support, the less problems you will face. :-)
Re: Lessons Learned (3.00 / 0) (#15)
by SparWeb on Tue Sep 30, 2008 at 04:47:43 PM MST
Sorry I didn't get this posted sooner.  I must have hit "preview" instead of "post".
Here is a drawing of the yaw mount I built last year.  I actually don't know what tapered bearing part number I did use, but the FAG part number was handy.  I'm sure you can find a cheaper bearing that would work fine!
At this point, I think the compression fitting would work, instead of the series of pipe fittings I actually used.  I think an even better third option would be to use the cable relief straps - neat things but I haven't got a picture handy.
Using one tapered roller bearing, instead of a mounted ball bearing on the stub, you have a lot less heavy hardware up there, too.
One limitation with this design is that the grease going through the roller bearing flows into the stub, and falls to the bottom.  Probably not a big deal, but you can't just pump the grease gun until is comes out the buffers at the bottom.  It will never happen!  I guess I haven't completely solved the grease monkey problem.
Steven Fahey
Re: Lessons Learned (3.00 / 0) (#16)
by luv2weld on Wed Oct 01, 2008 at 08:40:55 AM MST
Not only are you a generator builder, you're an artist too!!
Nice drawing.
Thanks for posting. I think I'll be using your idea.
Ralph
Re: Lessons Learned (3.00 / 0) (#17)
by SparWeb on Wed Oct 01, 2008 at 01:20:14 PM MST
Actually, my original background was as a draftsman.  Have 1000's of hours at AutoCAD by now.  Moving toward Solidworks now.
Reminds me that the career counsellor at school gave me a written aptitude tests and informed me that I was best suited to become a sculptor...
Steven Fahey
Re: Lessons Learned (3.00 / 0) (#18)
by frackers on Wed Oct 01, 2008 at 04:51:00 PM MST
Here is another one - took it down yesterday when I noticed it wasn't yawing properly as the wind got up.
This is a picture of the stub mast that goes up into the yaw bearing, the top thrust plate of the bearing has a groove about 1/16 deep in it after only 6 months of flying but it too deep in to get a clear picture of it! You can clearly see the steel filings stuck into the grease making a thick paste that stopped it from turning.
I guess I'll be looking for Teflon sheet now...
Re: Lessons Learned (3.00 / 0) (#19)
by Ungrounded Lightning Rod on Wed Oct 01, 2008 at 06:35:54 PM MST
Ever seen how a "fifth wheel" trailer mounts into a pickup truck bed?  There's a hitch system mounted into the pickup bed that's much like the one on a semi-tractor, only smaller.  (About a foot across.)  This is a plate on a bearing that lets it rock for-and-aft, with a little pie section cut out of it and a latch below it for the hitch pin.  The trailer has a hitch with a down-pointing pin (about an inch across) and a matching plate.  The truck plate is covered with thick grease.
Downside is that, when the trailer is not hooked up, you have this plate covered with grease in the truck bed.  Imagine what happens if you tether a dog back there...
There is a product to solve this problem:  A thick (maybe half-inch) Teflon washer that goes where the grease would go.  It has fingers in the inner hole that makes it hang onto the trailer pin when they're not connected.
One of those would provide all the heavy teflon sheet you'd need for several top-of-the-pipe-on-pipe teflon bushings.
  165 Scoop users have viewed this posting.
· luv2weld's Diary
