| I have been trying to find out if what I am planning to do can be done in the way I think it can. I have submitted a small flow chart to both Xantrex and Southwest that outlines a basic configuration that I feel will work, but would like to know if the Whisper controller will communicate properly with the Xantrex C60 to act as a diversion load to connected air or hot water elements.
I plan on setting this up in the next few weeks, and your advice would be appreciated.
Whisper 100
Whisper COntroller
Xantrex C60
Then from C60 one line to battery bank, second to diversion loads ie. air and water heating system.
Battery Bank to Xantrex Powerhub 1800 and battery bank to 6000/12000 watt inverter. Powerhub is used to hardwire to internal supply. This is an off-grid setup so protection is not required due to the utility pulling the lines and meter from my home. |
163 Scoop users have viewed this posting.
