| Well, I'm afraid the answer is, not a lot.
This is partly because I spent two weeks of it Spain. Wow is that place made for solar power or what? But surprisingly, not many Spanish take advantage of it. I did see a few solar heaters for hot water, but even less than I see in Greece, my usual holiday haunt.
I wonder why it is that those in colder climates like the UK long for free energy, and those that have it don't use it? There must be paper in that for someone.
What I did see there though was a fairly big windfarm, around 30 or so turbines, near the town of Casares. In the UK these are usually fenced off and I've always found it difficule to get near to one. In Spain however, where the spectre of health and safety is less prevalent, you can walk right up and touch it. So that's what we did. Blimey aren't they big? And scarey if you're standing directly under the path of the blades. While we were there we saw the blades change pitch as the wind altered, and could hear the machinery inside the tower making the changes. It was impossible NOT to be able to hear the blades, but I didn't think it was very loud, nor was I able to hear any of them when we a few hundred yards away.
Back at home I've been getting ready for the switch over to inverter powered lighting. This has involved changing some of the existing lights to cfl. In one of the bedrooms there was a 4 x GU10 halogen fitting, that's 4 x 50w! What the hell was I thinking of when I put that in? The young Slog that occupies that room will often go out and leave the light on! (sometimes all day!!). Out it came and in went a single CFL in a lampshade, so 200w down to 11w there.
My bedroom has a three bulb fitting built in to the ceiling fan, that was 3 x 60w tungsten which has been replaced by 3 x 7w CFL. 180w down to 21w.
I'm now well on the way to conversion and saving in the meantime. I realised that I wasn't going to be able to keep up with the demand when it came to winter, the time when I'll need more light because there is less sun but will generate less for the same reason, so I've ordered a second panel today to make my solar up to 160w.
I'm now wondering what is the best option during the summer. Does it make more sense to switch a panel off that's sitting in full sun or to just leave it on and dump the power if those are the only two options?
August | 13 comments (13 topical, 0 editorial)
136 Scoop users have viewed this posting.
