It is the busy time of the year for our RE system.
And the $3 HF meter connected as the battery SOC monitor started reading 0.4V too high. The batteries were run down quite flat and we really needed the power..
This system has been in place with no serious changes for a long time. The last change was the MPPT controller a few years ago.
The RE is completely ungrounded. 12V solar wired 12V into a SB2512iX, feeding 12V 660AH. There is no grid, no NG pipes. The well pipe is plastic, though there is no water near the electrical.
I break out "the back up charger". Meaning I pulled my truck up to the window, and ran jumper cables to the house batteries.
A while later, I go out to rev the motor a couple times. I grab the throttle cable and it feels like one of those little stray strands poked me. Ouch.
So I get a good solid grip on the do-hicky the cable goes to. YIKES!!!!
Something is strange. 12V doesn't shock me. About 18V gives me a good tingle. I get a meter.
Everything reads like it should... "12V".
Being a bit slow to catch on sometimes (you can see where this is going), I reach up and grab that do-hicky again.
Yup. YIKES!!!! again.
OK. I am barefoot on damp ground. But 12V doesn't bite me.
Meter from all the batteries negatives, to my finger is about 25V. I can almost believe that at the time because we have 2 12V systems somehow interacting.
But. Meter from all the batteries Positives to my finger is 40V DC.
And I can't imagine where that quantity would come from. Or how it would be linked to earth ground.
I considered the MPPT controller may be doing it, but it is not grounded. And it is connected to 660AH of batteries, then 12' of #10 cables to a G24 battery, then to where I am getting shocked. Seems like MPPT would be reading AC if there were any extra voltage not being absorbed by all that battery.
I considered something from one of the inverters, so all the load wires were disconnected. Still 40VDC.
Any ideas?
G- |
112 Scoop users have viewed this posting.
