Holes in HUB for studs
By Goahead, Section Wind
Posted on Mon Feb 16, 2009 at 05:10:36 PM MST
How many should i drill?
Hi Everyone
I finally got my hands dirty, and started to weld some iron and begun to build my 10ft wind generator. Just like Hugh 10Ft machine 24V
I known, i known... i still need to re-enforce the connection between the Hub to Yaw pipe :)
The Hub has only four holes to insert the M12 studs.(pictures shows 6 but only 4 are fully drilled)
->Is it ok for a 10ft machine having 4 or should i drill 4 more holes in it in a total of 8?
->If i only drill 2 more holes (total of 6), will it get unbalance when spinning?
Other Questions..is there a problem when:
->Deviation in tail angles? (the 20 degrees is ok, but i believe i don't have the 35 degrees accurate..maybe +/-2 degrees angle..hard to check)
-> The alternator offset is 13,3mm (not 12,5)
-> Yaw pipe is 75mm diameter not 60.3.
Ill post more pictures when all mechanical parts are finished...
This are just simple questions to be on the safe side.
Kind regards from Portugal
Goahead
Holes in HUB for studs | 3 comments (3 topical)
Re: Holes in HUB for studs (3.00 / 0) (#1)
by luckeydog on Wed Feb 18, 2009 at 06:36:12 AM MST
4 is fine for a ten foot machine.
 As far as your angle off by +/-2 you will have to play around with the tail weight
to get it to furl at your desired wind speed.
looks to me you are off to a good start.
Have fun
Luckeydog
wind gens are much funner to watch than solar panels. Broomfield,Colorado
Re: Holes in HUB for studs (3.00 / 0) (#2)
by Eirbyte on Thu Feb 19, 2009 at 04:46:08 PM MST
Hi Goahead
Looks good what did that hub come from.
Bureaucracy was the counterpart of cancer, it grew bigger and destroyed everything except itself
Spike Milligan
Re: Holes in HUB for studs (3.00 / 0) (#3)
by Goahead on Wed Feb 25, 2009 at 11:14:16 AM MST
Hi Eirbyte
Dont know...
Its was a friend of mine that got it from another friend, bla bla... that is a mechanic :)
But maybe it came from an old Peugeot car, since he works on a Peugeot garage.
He had 2 of then laying down (i guess its not common to see 4 holes in a hub any more)
I didn't moved any further in metal parts (just made the tail) so i started with the blades..
To keep this post running, here is a picture of the tower. 11,9 meters long
0,9 meters will be put inside concrete, so at the end it will be 11 meters
It came from the power company...since they didn't want it, they cut it from its original place and i manage to take it to my place with a friends truck.
The tip of the tower is 15 x 15 cm so a believe a should use a pipe to put the generator a bit higher gaining a bit of clearance between blades and tower.
All ok , since its been a 0 euros project so far :)
Goahead
· Also by Goahead
