Blade carving
By trumpets3u, Section Diaries
Posted on Thu Feb 19, 2009 at 06:47:43 PM MST
Wind
on the view in the blade carving> Looking at the end views ( in shows 3) is the trailing edge on the left or the right side. I got my blades marked out and want to make shower that I'm correct.
                    Thanks Brian
Blade carving | 10 comments (10 topical)
Re: Blade carving (3.00 / 0) (#1)
by TomW on Thu Feb 19, 2009 at 12:11:51 PM MST
Brian;
The trailing edge is the thinner edge, usually a knife edge as opposed to the rounded, blunt edge of the leading edge.
The easy way to remember is to think of an airplane wing. The thick edge is to the front and the back has thin flaps which is obvious when you look at one.
Just one way to understand without having to understand how it works.
Re: Blade carving (3.00 / 0) (#2)
by paulpic on Thu Feb 19, 2009 at 12:49:44 PM MST
You must have had some sort of picture but it doesnt show.The trailing edge is the
one that is at the bottom side of the rotation.Its usually the first edge you cut when carving the blade.The leading edge is the one you dont touch and is square to centre and tip.
Re: Blade carving (3.00 / 0) (#3)
by lglagasse on Thu Feb 19, 2009 at 03:31:45 PM MST
Hi trumpets3U:
I think the question that you are asking refers  to weather you are making clockwise or counterclockwise rotation blades. For CCW, as the blades are laying round side up, the trailing edge would be on the right. Fat side to your left, skinny side to right. For clockwise rotation it would be reversed. That would be as you are looking at the "end" view. Flat side faces the wind.
Good Luck
lglagasse
Re: Blade carving (3.00 / 0) (#4)
by trumpets3u on Thu Feb 19, 2009 at 03:48:20 PM MST
Does it matter which way the turbine turn? As you look at the end view of the R30,R60, R12 on the web sight what do you call the flat side? The top or the bottom?
                           Thanks Brian
Brian
Re: Blade carving (3.00 / 0) (#5)
by lglagasse on Thu Feb 19, 2009 at 04:20:11 PM MST
Hi trumpets3u:
Which web site? Nunbers-r30, r60 don't know.
Upper Right corner on this site, go to FAQs section, homebrew, Blades 101, good pics and info there. The blades are CCW rotation.
You ask which is up. As you are making the blades the round side is up, flat side down. Just as Tom W said about the airplane wing.
CCW or CW rotation. Are you following a plan from this site??
Good Luck
lglagasse
Re: Blade carving (3.00 / 0) (#7)
by Ungrounded Lightning Rod on Thu Feb 19, 2009 at 07:36:39 PM MST
To make that clearer:
The broad humped surface of the blade is downwind, the flat or nearly-flat surface is upwind.  (This is the reverse of a propeller, while all the rest of this is just like a propeller.)
The leading edge (forward as it spins) is rounded, the trailing edge is sharp.
The blade is angled so the leading edge is more upwind than the trailing edge.
The blade is usually twisted so it is NEARLY flat to the wind out at the end and points much more into the wind near the hub.
Re: Blade carving (3.00 / 0) (#8)
by trumpets3u on Fri Feb 20, 2009 at 04:53:45 AM MST
That would be on the other power web page under  wind than go to the 10' turbine and than go to Wind turbine blades.
Brian
Re: Blade carving (3.00 / 0) (#6)
by kraft1191 on Thu Feb 19, 2009 at 07:29:10 PM MST
Brian,
I used Hugh Piggotts "How to build a Wind Turbine" illustrations and after a little imagination the shape became clear.  I'm no wood carver and was afraid I would ruin my $65 worth of BASS wood.  Anyway a trip to Windchasers in Ontario proved I was on the right track.  Hugh's book works!
Bill
Re: Blade carving (3.00 / 0) (#9)
by trumpets3u on Fri Feb 20, 2009 at 02:14:40 PM MST
I did a practice blade today, I got it done and found out that the rotation would be counter clock wise, but I saw where I can speed it up and change the way I did it.
I will be using eastern white ceder. ? would white pine also work?
                      Thanks Brian
Brian
Re: Blade carving (3.00 / 0) (#10)
by imsmooth on Fri Feb 20, 2009 at 05:21:45 PM MST
I'm using Radiata Pine.  30,000psi strength.  I will coat with Epoxy paint.
Jonathan
  135 Scoop users have viewed this posting.
· trumpets3u's Diary
