Two years without furling tail. 22 foot
By harrie, Section Diaries
Posted on Thu Apr 16, 2009 at 03:25:14 AM MST
Some areas and designs may not need furling
Its been awhile since I have posted, but some here might be interested in how my 22 foot has performed in the last two years. I am glad to say, that I have had zero trouble with this duell rotor. As I have written in my previous posts, I am not off the grid, so I have been happy to have less output from the turbine by keeping it in stall. The 22 foot RPM is Usually around 60 to 80, and charges my 48 volt bank up to 30 Amps depending on the Wind speed. It Averages around 12 amps, which is more than enough to keep the batterys charged. Because of the 140lbs of blades, I feel it has the flywheel toque needed to supply substancial amps at low RPM, and very low winds.I get from 2 to 8 KW a day.
The wind in my area rarely is over 30MPH. I have saw 45MPH, and the turbine has never broken stall. I have at times shut it down, if higher winds are forcasted. I never worry about it running away, therefore I feel a furling tail is not neccesary. Yes, It is possible to lose a wire or two, and than of course it would take off, but that I think would be the same even if it would furl.
My 18 foot has been flying for three years now in 12 volt, and does have a tilt up furling, but even that one rarely does furl. It is also in stall, and runs at about 50 RPM. This turbine has also given me zero trouble.
Below is picture of the 22 foot and the 18 foot.
Two years without furling tail. 22 foot | 5 comments (5 topical)
Re: Two years without furling tail. 22 foot (3.00 / 0) (#1)
by zap on Wed Apr 15, 2009 at 10:06:04 PM MST
2 years without problems is very nice.
Thanks for the update.
zap
Re: Two years without furling tail. 22 foot (3.00 / 0) (#2)
by richhagen on Thu Apr 16, 2009 at 03:03:54 AM MST
Nice to hear from you, and good to hear that your turbines are performing so well.  Rich
Re: Two years without furling tail. 22 foot (3.00 / 0) (#3)
by oztules on Thu Apr 16, 2009 at 03:17:30 AM MST
I guess that means the blade erosion is a non-event too :)
Nice to see trouble free flying.
....oztules
Re: Two years without furling tail. 22 foot (3.00 / 0) (#4)
by willib on Thu Apr 16, 2009 at 05:46:29 PM MST
That is Great news Harrie !
I'm glad to see your mill is still doing well.
Your craftsmanship and attention to detail is surpassed by few people.
Where did you get your golfcart batteries, were they used?
..Bill
Carpe Ventum (seize the wind)
Re: Two years without furling tail. 22 foot (3.00 / 0) (#5)
by harrie on Thu Apr 16, 2009 at 06:22:37 PM MST
Hi Willib. We have a L&M supply in this area that is kind of like Fleet Farm store. They were new in 2004, and are still holding up great. The turbine seems to hold them in float most of the time, so they are not abused much. Thanks for the comment.
Harrie.
  173 Scoop users have viewed this posting.
· harrie's Diary
