Good motor?
By bazz, Section Wind
Posted on Fri Apr 24, 2009 at 01:37:00 AM MST
I'm looking to do a project this summer.
Can anyone tell me a good motor to use? I know the Ameteks are big, but I have notice people want an arm and a leg for those. Any other good motors hat are something like those but not hundreds of $$
Good motor? | 14 comments (14 topical)
Re: Good motor? (3.00 / 0) (#1)
by SACONGO on Thu Apr 23, 2009 at 11:40:33 PM MST
If you what a good high amp low rpm motor for a good price.
http://cgi.ebay.com/Ametek-type-Wind-generator-dc-servo-motor_W0QQitemZ130301248580
This is the same size motor as ametek 99v but a much better price.
  1. volt @ 350rpm
  2. amps @ 350rpm
Goodluck!
Sacongo
Re: Good motor? (3.00 / 0) (#2)
by ghurd on Fri Apr 24, 2009 at 12:32:01 AM MST
It is a decent rule-of-thumb, but nobody should spend spend $156 based on luck and "Rare".
"these motors max out at around 19 amps"
and
"All sales are final"
would make me a bit concerned.
I can not find where your 14V at 350RPM and 12A at 350RPM came from.
Physic?
Looks like spam to me.
Ghurd.info
Re: Good motor? (3.00 / 0) (#4)
by bazz on Fri Apr 24, 2009 at 05:40:41 AM MST
Yeah...I totally agree with you on that!
This is one of the problems that I have...there is all this possibly miss leading information such as...this motor is just like the Ametek blah, blah, but no  real info.
It be nice if it were true, to have a little chart (from the manufacture)to compare the two motors.
So what would be a good motor to look for? Or things to keep in mind for a motor?
Re: Good motor? (3.00 / 0) (#12)
by willib on Fri Apr 24, 2009 at 12:36:20 PM MST
You could allways find a DC Treadmill motor , there are some nice ones that people just through out.
I saw one at a local second hand store for about $25 , for the whole treadmill .
Good luck
Bill
Carpe Ventum (seize the wind)
Re: Good motor? (3.00 / 0) (#9)
by SACONGO on Fri Apr 24, 2009 at 11:39:05 AM MST
Hello, First let me say im not the one selling these motors. I got my numbers by spinning the motor use a digital tachometer (American made) and its produce 14v@350rpm i didnt get to go that high rpm with the shorted amp but i did get to 250rpm it was putting out 7.3amps i did both test twice. My math could be wrong what amps do you think it should put out @350rpm?
sacongo
Re: Good motor? (3.00 / 0) (#11)
by kurt on Fri Apr 24, 2009 at 12:03:44 PM MST
shorted amps is a sales gimmick you need to test the amps into a 12v battery for a real test that means anything..........
IRC inst.
Re: Good motor? (3.00 / 0) (#3)
by Basil on Fri Apr 24, 2009 at 05:36:48 AM MST
Try this site. http://www.windstuffnow.com/main/ I got a ametek motor from him. I have 3. Great for learning. I mad a ceiling fan out of one of them. I get up to 2 amps most the time. I did see a 17 amp spike when we had A BIG STORM with very high wind. That beat my 4 amps max last year I saw. I learned that day these motors can make power if in the right wind.
Bad luck or none at all.
Re: Good motor? (3.00 / 0) (#5)
by bazz on Fri Apr 24, 2009 at 05:50:32 AM MST
I have been there before. He's out of stock of the Ametek 38 , and I have read that the Ametek 38 is good for trickle charge.
Re: Good motor? (3.00 / 0) (#6)
by bazz on Fri Apr 24, 2009 at 06:12:55 AM MST
I'v been looking around a bit more and have found a comparison of the ametek to Indiana. I guess they look like a good motor. Does anyone have any experience with them?
Re: Good motor? (3.00 / 0) (#7)
by pepa on Fri Apr 24, 2009 at 06:50:40 AM MST
i have a indiana 48v that puts out more volts than my ametek 50 in bench test using the same drive motor and sprockets. hope this helps, pepa.
Re: Good motor? (3.00 / 0) (#8)
by Norm on Fri Apr 24, 2009 at 08:20:20 AM MST
  As fast as I can pedal( I calculate a
conservative 80 rpm=960rpm 'Ametek 30') 12 volt
NiCad reading 13 volts at the start when hooked up...
  multimeter reads 15 volt charging rate and
barely 2 amps.
( :>) Norm
Re: Good motor? (3.00 / 0) (#10)
by SACONGO on Fri Apr 24, 2009 at 11:40:27 AM MST
sacongo
Re: Good motor? (3.00 / 0) (#13)
by wooferhound on Fri Apr 24, 2009 at 04:07:14 PM MST
OK ,  here is the math, it's not tough and will let you find good electric producing motors without too much problem
Lets say you are looking at a motor that 2600 RPM at 24 volts
Now divide the RPM by the voltage, 2600 / 24 = 108.33
you will need 108.33 RPM to make 1 volt
Now multiply the 'RPM per volt' times your planned Cut-In voltage
108.33 RPM times 12 volt Cut-In voltage equals 1300 RPM
There you go, your motor will make 12 volts when it reaches 1300 RPM
A proper Flooded Lead Acid battery is not really fully charged until it reaches 14.6 volts.
108.33 RPM times 14.6 volt Full-Charge voltage equals 1582 RPM
Too doggone fast.
That should be enough to figure out for yourself which one is a good generator.
W o o f -={(
Re: Good motor? (3.00 / 0) (#14)
by bazz on Sat Apr 25, 2009 at 07:57:40 PM MST
That helps a lot! Thanks!!
  98 Scoop users have viewed this posting.
· Also by bazz
