| I'm soon to be moving off-grid. It's an econmy based move, I can't afford the mortgage and the rental. So, I got a 40' container delivered and I'm moving a 35' trailer out there next week.
Anyway, I just wanted to do a sanity check on the following basic system.
I have a 5kW gas generator that will be used to charge the batteries. I am purchasing 6-8 T105 batteries for 660-880aH. I read that charging at 10% of the bank capacity is the way to go. So I can charge at 60-80 amps, depending on the bank size.
Of course, since I am charging from a generator, I want the shortest charge time I can get, while taking care of the batteries. Assuming I stick to using about 20% of the batteries capacity, I will need to charge around 120 to 160 aH each day. That should take about about 3.7 hours per day with a 60 amp charger. Does that seem about right in reality? I calculated that simply by 120/6*1.4. Is that a reasonable way to figger it?
So, I need a charger. Am I better off getting 2*40 amp chargers, or getting 1 larger charger? Anyone have any reccomends for brand/model of charger? I need a simple, cheap, dumb charger, due to costs. While I know that I am too poor to buy cheap, I am serioulsy finacially restricted. If I can get a couple of years out of the system I will be happy.
I can see that undercharging is going to be my biggest problem, leading to sulfation and early battery death. I have built a pulse desulfator and am playing with that. Can I use the desulfator to compensate for lack of equilization charges?
Thanks for the help!
110 Scoop users have viewed this posting.
