We cast our first magnet plate this past week. The resin dried outside here in MI, so it took about 18 hours to harden (using half the hardener as suggested by the book.) We ran into a few issues that I'm hoping have simple answers. So we come to the collective old sage seeking advice. :)
The resin shrank, as we knew it would, but more than expected. We poured on a level surface and filled the mold, when we put the top plate on resin was being squeezed out all around the perimeter of the circle. When it dried, as you can see in the pictures, the edges are barely covering the magnets. We ended up with one big pocket that doesn't have resin, though we're going to try to patch that when we pour the next one.
So, did we do something wrong in the pour, or is this just the way they look before you clean them up?
The next thing is, I don't understand the directions for the middle 6.5" disc, because they call for it to be 1/2" thick, which is the thickness of the magnets. That makes sense except when you remember that the fiberglass mat on top of the magnets adds thickness, which it did, making the resin run on top of the 6.5" disc, which I had to chip out. Should that disc really be 5/8" thick to allow some room for the fiberglass mat?
That leads to a bigger question about tolerances. The book says there should be 3/16" between the face of the magnets and the stator. However, the resin+mat on top of the face of the magnets is like a heavy 1/16" thick, so is the 3/16" including that, or is it 3/16" from the surface of the resin? Or are we supposed to sand the fiberglass down almost right to the surface of the magnets? It seems like if we start sanding on them, the mat is going to be exposed and then just get all frayed on the surface.
We have three more plates to pour, but would like to know if there's something else we should know before doing those. Should we open the mold after a few hours to add a little more resin to fill the space that's been vacated by shrinking resin? Should the 6.5" disc really be a little thicker? What kind of gap are you really talking from the face of the magnet to the wire in the stator?
Thanks in advance for all of the help! I'd had a set of model blades spinning in the backyard not connected to anything for the last six months and I can't wait to get them connected to something! I want to just forge ahead, but I also want a well balanced assembly that's going to adequately protect the magnets from the elements. Thanks again!
(The resin is bondo resin and we used the cloth rather than the shredded stuff.)
.JPG) Full Res Pic
.JPG) Full Res Pic
.JPG) Full Res Pic
.JPG) Full Res Pic
Fixed your gross violation of image width restrictions. I only do that once, please do not post big wide photos without proper width tags. Next time the post goes away.
TW.
