load or no load?
By greenkarson, Section Hydro
Posted on Thu May 14, 2009 at 10:34:50 PM MST
load or no load?
my turbine puts out anywhere from 24 to 100 volts dc with no load. If im putting out more then 24 volts with no load is that enough to charge my 24v battery bank or does it have to be 24v with a load.
thanks
load or no load? | 2 comments (2 topical)
Re: load or no load? (3.00 / 0) (#1)
by wpowokal on Thu May 14, 2009 at 05:16:40 PM MST
Simple answer yes.
Once your turbine reaches battery volts plus blocking diode volt drop charging will commence and from then turbine terminal volts will be battery volts, basically.
allan down under
"Dream as if you'll live forever, live as if you'll die today." James Dean
Re: load or no load? (3.00 / 0) (#2)
by tanner0441 on Fri May 15, 2009 at 11:35:00 AM MST
Hi
Running a wind turbine without a load can be the least sensible option. It can run away and very quickly causing damage or pain.  Even with a load on I was surprised how quickly the amp meter climbs in a brisk wind.
Brian.
  105 Scoop users have viewed this posting.
· Also by greenkarson
