| i'm making a Piggott 4' at 24v. 155 turns of 19 awg per coil. it calls for a cut-in at 300rpm. i made a (rough) test rig where i set the coil on a thin piece of plexi just above the magnets. i'm sure i need to find a way to suspend the coil w/ nothing in between for an accurate account, but for now, i just want to see if i calculated everything correctly.
i spin the rotor to 100 rpm and get 1.3v and 3.9v at 300rpm. according to the homebrew book, i multiply that by 1.4 for peak AC when converting to DC. gives me 5.46v. next multiply by 2 (number of coils per phase), 10.92v per phase. next is the part i'm not sure about. it says multiply by 1.73 (square root of 3, 3 phases). gives me 18.891. now this is the TOTAL output of all 3 phases (6 coils)? after i subtract rectifier loss of 1.4v, gives me 17.491v at 300 rpm. not enough for charging a 24v battery.
so, either i misunderstand the calcs, my coils are not right, or (most likely) i am seeing a hefty loss in voltage since there is a barrier between the coil and the magnet.
just wanted to make sure i was doing the math right (and understanding everything) before i worked on a better way to suspend the coil.
thanks!
Dave
79 Scoop users have viewed this posting.
