| Gales force winds, low temperatures and the batteries don't like the high charge current when they are near 0 degrees (Celcius that is!!) - the voltage floats up very quickly despite the charge level being low so no alternative but to start loading them down before the inverter goes bang - so I've ended up with less in the batteries that I started with :-(
I've got them in the middle of the paddock at the moment, in the open air so anything I do will be an improvement I think. I'm thinking 6x2 timbers as a base on 4x4's in a pallet type construction, 40mm polystyrene under and round the batteries (because I have loads of offcuts from another project) but not sure about the top as I want plenty of air round them so the fumes don't get to the switch/fuse panel and the inverter.
Any hints?
103 Scoop users have viewed this posting.
