| I can run a cable around the frames on the panels if I need to & was planning to bury pvc to the house for the wires coming in from the panels. Should I use aluminum conduit instead so I can ground it? I'm running about 30' on a 12v system. It would be much easier if I don't have to worry about it but the easy way usually isn't the right way so I'd value your input. thanks |
103 Scoop users have viewed this posting.
