john
He has a contact page: http://www.homebrewhydro.com/contact/ shoot him an E-mail.
Have Fun.
Curbie
I ordered the 540 and tested it with a cordless drill, it lit a 100W lamp no problem. I hope to make a bucket hydro typer runner and setup. Hopefully, Zachary can help me out. Thank you very much
John[ Parent ]
Keep in mind too that the windblue will take a while to break in. Over a period of a month or more of running 24/7 the voltage kept going up -- as it got smoother (less mechanical resistance i suspect).
So you can expect it to get better and better for a period after you make it.
best of luck & thanks for checking out my half-arsed system!
-zachary[ Parent ]
I have found some new PVC 50mm/2inch pipe. There are two types. VP which is thicker walled. and VU which is thin walled and more flexible, as well as half the price. Of course I'm leaning towards the cheaper stuff. As the head is only 10 meters, pressure shouldn't be a problem.
VP pipe (in Japanese)
http://cart02.lolipop.jp/LA11158856/?mode=ITEM2&p_id=PR00101682699
VU pipe (about 8$ for a 4meter length)
http://cart02.lolipop.jp/LA11158856/?mode=ITEM2&p_id=PR00101682709
Can get about 50 meters for 200USD. This should be able to complete my pipeline. Any recommendations here? I don't think it can be buried, and our winters are fairly mild, usually around 30F. I'm not looking to go off grid here, just to do outdoor lighting and or emergency house use.
Can you use flexible hose, like fire hose, in a hydro system? Or partially, ie from the penstock, use 3 inch pvc, then into a flexible hose, and back to 2inch pvc at the turbine?
hose like this?
http://item.rakuten.co.jp/tuzukiya/indus-sd-5020/
http://www.bidders.co.jp/item/117807970
thanks all for your patience.
I would expect the woven fire hose to have higher friction -- also I was a bit paranoid about suction causing a collapse and/or having trouble filling, but then I'm doing a bit of a siphon.
so I dono.. probably be OK ??[ Parent ]
You would have to ensure that it wouldn't collapse from suction or get over pressured when valves are switched, etc. [ Parent ]
I was also worried about collapse, but like you imply, it is being used as a "pump" hose rather than suction hose, got to work on pricing it all out and hopefully get going soon,
thanks again,
