RV solar & inverter wiring diagram
By coopfish, Section Newbies
Posted on Tue Jun 30, 2009 at 04:17:46 PM MST
I need some advice on wiring a 20watt solar panel & 500 watt inverter to my 12volt rv battery
RV solar & inverter wiring diagram | 1 comment (1 topical)
Re: RV solar & inverter wiring diagram (3.00 / 0) (#1)
by mettleramiel on Tue Jun 30, 2009 at 05:35:07 PM MST
While that's very vague, if all you want to do it run  a load (hopefully not 500watts or that little panel take forever recharge your batteries, all you need is a charge controller. A cheap 7amp charge controller can be had for under $30. Then all you do is hook up the panel to the charge controller and then the charge controller to the batteries. The inverter will just connect to your battery as well. That's about as simple as a solar system can get. Is there maybe something more technical you were meaning to ask?
  53 Scoop users have viewed this posting.
· Also by coopfish
