| As posted in LenzII update, I'm testing my alternator before I put it in the wind.
But I really don't know what I'm doing and could use some help.
I've mounted my alternator in a milling machine where I can drive the rotors at various speeds.
I've spun it through a speed range and measured the open DC voltage.
This morning, I hooked up a pair of auto headlights to the DC side of the rectifier. At first, I ran it slow..about 70 rpm..and gradually increased the speed while I watched for temperature rises in the components.
Here's a sketch of my set-up:
How do I determine how much power I'm making?
I can measure the any leg of 3ph AC voltage at A1,A2 and A3.
I can use a clip-on amp meter to read the AC current on A1, A2 and A3.
I can read the DC volts at B1 and B2.
And I can read the resistance of my headlamps.
So now what...? P=volts^2/Resitance=IR^2....this stuff is faintly ringing a bell upstairs....uhhg! Where do I take measurements?
I'm hoping to determine some sort of "safe" power level so that when the Lenz is flying, I can take a few readings to determine if it is operating in at a safe wind level...or if I need to shut it down and wait for calmer weather.
Thoughts about power?
Thanks, Rob
165 Scoop users have viewed this posting.
