| Hi All,
I'm looking to upgrade the alternator on my lawnmower/alternator battery charger. Right now I have a Delco 7122 that I can get 50A out of. My engine is a 5.5HP, so I should be able to easily get 100-150A out of it. Right now I run the motor not far above idle. The motor is a horizontal shaft, which makes it a little harder to connect to.
So, what I'd like is an alt that has the same mounts as a Delco 7122, with an output range of 150-200A, with an external reg.
So far, all I have been able to find has an internal reg. So, does anyone know how to work with an internal reg to get equalizing voltages? Or know where to get one with an external reg?
As predicted by this group (and the laws of physics enforcement dept.) it takes quite a while to put a substantial charge into the bank.
Thanks! |
126 Scoop users have viewed this posting.
